Case VAI date of manufacture
Tom
09-22-1999 12:01:19
I just picked up a Case VAI serial 6002935. What I can't figure out is what year it is. The first serial number in 53 is 5750001, the first one in 54 was 6011001 and in 55 they started with 6038001. When did they use numbers starting with 600????
sammy the RED
09-28-1999 19:30:54
 Re: Case VAI date of manufacture in reply to Tom, 09-22-1999 12:01:19
My book showes that 1953 production ended with #6004357
Shaun In wisconsin
09-23-1999 15:11:45
It is a late model 1953 tractor
if you look you can see that the serial in "53" starts with 575 and the "54" starts with 601.
there for that puts your machine into the late 53's
Tom
09-23-1999 20:20:22
 Re: Re: Case VAI date of manufacture in reply to Shaun In wisconsin, 09-23-1999 15:11:45
I don't beleave it is a 53 because in 53 the first serial number was 5750001 and the last number was 5756831 with a total of 6831 V searies tractors made. Then in 54 they started with 6011500 and ended with 6014270 and in 55 started with 6038001 and ended with 6040248. The information I have tells me there was 6 tractors made in 56 but I don't have any serial numbers, could this be one of them? Does anyone have the serial numbers for them last 6 tractors?
spf
09-23-1999 15:26:38
Sorry I forgot to add what Dave Erb quotes, if you read to the right side on page 27 it does say that Erb may have made a few mistakes.
If you have more questions please let us know what book or manual ect... that your using as a referance. but I do beleive that you may have been referring to the JICCA old abe spring of "99"
spf
09-23-1999 15:26:29
H. L. Staples
09-23-1999 14:25:30
You have the same information that is in my copy of Hot Line Farm Equipment Guide. Could the number you have be messed up to the point that it is being mis-read? If you find the answer let us know. The Case 200B,210B,211B. started 1958 with #6095001 best I can tell these were a similar tractor the the VA series.
