CC3/CC4 Question
L.C.Grey
04-11-2005 16:20:28
Do all CCs have the front axle pivot and wishbone mounts in place or are they only on CC4s?
The machine in question is a '36 CC on a narrow front, but has a pivot for a wide axle and has all the studs, complete with nuts and washers, under the oilpan for the wishbone.
I'm thinking maybe it could be a CC4 that someone had both frontends for and the let widefront go at some time in the past.
Can anyone educate me a little on this?
CASEPOWER
04-11-2005 16:38:14
 Re: CC3/CC4 Question in reply to L.C.Grey, 04-11-2005 16:20:28
When the CC first went into production, the cast housing weighed 50 pounds. They had some breaking problems. A lot were switched to wide fronts. They later went to a 100# casting, than a 150# casting, which is what the DC's use also. Many farmers bought both front, and changed them as needed. Your tractor could have very well have been a wide front originally. As to whether the studs would have been in it, if it was sold as a narrow front, it should have had bolts that are cut off, with a flat screwdriver slot in them. As for the pivot, it was on all of the castings I have seen.
L.C.Grey
04-11-2005 19:13:45
 Re: CC3/CC4 Question in reply to CASEPOWER, 04-11-2005 16:38:14
Well the pivot didn't make me think about it as much as the presence of the studs with nuts and washers still in place.
I'm thinking since the C was actually a downsized L, the C was actually ahead of the CC in design. Knowing they were both produced simultaneously, I figure all C series must use the same front bolster, as all Cs have the bolt pattern for the narrow front. I'd never looked under a CC and noticed the pivot before.
I'd read before about the broken front ends on them and the process Case went through to strengthen them up.
CASEPOWER
04-11-2005 19:21:44
 Re: CC3/CC4 Question in reply to L.C.Grey, 04-11-2005 19:13:45
I also have a CC with bolts and washers in place, but have one with the studs, with the screw driver slots also. Without something in there, it will leak oil.
L.C.Grey
04-12-2005 16:10:35
 Re: CC3/CC4 Question in reply to CASEPOWER, 04-11-2005 19:21:44
Thats good to know..... ...
