Case 411 shift pattern??
Galen Ishman
04-11-2005 10:46:37
I recently aquired a 1958 Case 411 tractor and it is an 8-speed transmission with the Hi-Lo built into the same shifter. What in the world is the shift pattern??? The 730s were basically the same tractor and had a seperate Hi-lo shift lever. Can the 411 be converted to this type??? Thanks for the help!
Jim McVay
04-12-2005 09:30:38
 Re: Case 411 shift pattern?? in reply to Galen Ishman, 04-11-2005 10:46:37
I have what it takes to convert for $400 plus freight. You have to reuse your stick but the rest is 730 grove tractor parts. Call at 863-673-0363 or e-mail at [email protected]
JHH
04-12-2005 06:42:46
type 400 SHIFT PATTERN in the search window at the tope of the discussion page. There is a wealth of information available here but you have to search.
Cory R. aka M man
04-12-2005 08:06:50
 Re: Case 411 shift pattern?? in reply to JHH, 04-12-2005 06:42:46
It is the same as the 400 we own a 1955 Case 400 and we have 8 speeds ahead 2 reverse in a high low shift. Top of the range we have 5, 6, 7, 8, and reverse. 8 is road gear. And you have a high reverse. In the low range 1, 2, 3, 4, and low revese. and in the middle of the range is the belt gear. i hope this helps
