Switches
jal-SD
04-11-2005 06:47:48
John, saw your post to Caseman D about switches; do you have a 2 position one for a '46 VAC? Mine smokes & generator (w/cut-out) won't charge, but will discharge the battery when tractor is off. Post back if you have one. (My $0.02 worth. jal-SD)
Alberta Mike
04-12-2005 14:40:27
 Re: Switches in reply to jal-SD, 04-11-2005 06:47:48
Take the wire that goes to the resistor and just ground it somewhere else. That will cause the generator to operate at FULL CHARGE (like the #2 setting on a 3-position switch or the #3 position when the lights are on). In any of the 3 positions, that wire grounds out (through the resistor in the first postion, directly to ground in #2 postion, and through the tractor lights in the #3 position). If you still have problems, then your concern is elsewhere.
C. Amick
04-12-2005 05:01:21
Hey, I called my local automotive electric shop and they said that they have a Cole Hersee catalog. If you call around, you may find someone locally that has one.
jstpa
04-11-2005 21:01:57
Jal,
One other thought, some of the original cutouts, delco anyway, had a third terminal on them for the field. if yours does you could try hooking your field out of the generator to it and seeeing if that makes it charge. for what its worth, jstpa
John Saeli
04-11-2005 18:23:37
Hey Jal: Sorry, but I don't have that switch. Thanks
C. Amick
04-11-2005 09:35:47
If John can't help you, you might get an automotive electric shop to order one for you. They are made by Cole Hersey ($60.00). They were also used on JD's and Molines. So JD dealers and AGCO dealers may have them, but probably more $$$$.
C. Amick
04-11-2005 09:54:18
 Re: Switches in reply to C. Amick, 04-11-2005 09:35:47
Sorry it's "Hersee" not Hersey. Why won't one of these switches work, if they are rated for 6V (see link below).
http://www.ekomarine.com/c/Cole_Hersee/index1.htm
jal-SD
04-11-2005 11:07:20
 Re: Switches in reply to C. Amick, 04-11-2005 09:54:18
Thanks for the info, I'll give it a try. (Another $0.02 worth. jal-SD)
C. Amick
04-11-2005 13:10:14
 Re: Switches in reply to jal-SD, 04-11-2005 11:07:20
I got to thinking, since there is no voltage regulator the VA switch has a resister on it to keep the generator from blowing out the light bulbs. I guess that's why the correct one is more expensive than the $15.00 ones on the web site I gave you?
jal-SD
04-11-2005 13:49:47
 Re: Switches in reply to C. Amick, 04-11-2005 13:10:14
Yep, I gotta have the resistor one, its the resistor that smokes, think its shorted out. Switch pulls in & out, smokes all the time the tractor is running, no matter what position the switch is in. I'm thinking thats why the battery always goes down when its connected, shorting into the generator somehow. How generators, regulators, mags, coils or anything electric work are wwwwaaaaayyyyy beyond my understanding level. To me, the charging & sparking systems are MAGIC, & I don't understand magic at all! (Another $0.02 worth. jal-SD)
Glen in TX
04-12-2005 21:45:19
 Re: Switches in reply to jal-SD, 04-11-2005 13:49:47
Like these guys said a Cole-Hersee dealer can get them. I've seen them at wiringharnesses.com site too. Same brand switch. I carry some Cole-Hersee stuff for trucks but not this switch and have seen them in my catalog. Someone in your area can order them.
