general questions 800 and 730
INCase
04-11-2005 05:32:23
Been working on "unsticking" my 730 for 2 years now. Still can't get it to budge. I'm at the point of giving up on this motor and parting the engine out. I've found a running 800 gas w/ a patched block reasonably cheap. I can buy just the engine or the whole thing. Its missing the hyd unit but I can use the one of the 730 (I presume). The patch on the block is "old" (looks like its been there for a long while) and is up "high" on the block just under the heads on the left side. I've seen several in salvage yards this way. I've also noticed about 75% of units in salvage yards are COM's. what are the inherent problems with COM's? what might a good $ be for this beast? the rear tires look original but are worn down badly, rear rims are so/so. 1 new front tire. gage cluster is bad (glass broke). homemade 3pt conversion. Thanks.
Patrick (Mich.)
04-11-2005 16:05:27
 Re: general questions 800 and 730 in reply to INCase, 04-11-2005 05:32:23
The 800 sounds pretty rough--I wouldn't pay any more than $500.00 based on how you describe it. I bought a 730 gasoline Case-O-Matic for only $750.00 last Summer, needing work but not junk either. The hydraulics from the 730 should work on the 800, provided that your 730 is NOT a Comfort King. Another thing you may consider if you buy the 800 is to sell your 730 complete or mostly complete if you remove the hydraulics. Why are most of the salvage tractors COM? A few reasons I believe: 1. Case sold quite a few of them early in the 60's. 2. Many operators didn't understand how to use or maintain COM and abuse of the convertor resulted. 3. When the COM actually wears out from hours, it is far more expensive than a conventional clutch to replace or overhaul.
INCase
04-12-2005 08:55:08
 Re: general questions 800 and 730 in reply to Patrick (Mich.), 04-11-2005 16:05:27
Thanks for the feed back. I am going to go back and hear it run next week probably. I'm thinking $750 is tops. Both are mostly complete and Between the 2 units I should be able to get one decent tractor provided the COM is ok. but I could switch the motors (both are gas) as the 730 is a dry clutch 8 speed. whats the best way to "test" the COM? and do they take special oil/fluid??? thanks again!
Patrick (Mich.)
04-12-2005 21:41:24
 Re: general questions 800 and 730 in reply to INCase, 04-12-2005 08:55:08
Yes, you should be able to switch the engines but you might also have to swap the oil pan--don't know for sure. Case-O-Matic uses automatic trans. fluid or Case TCH Hy-Tran. If the convertor is working properly, it should engage to drive within a few seconds after you release the clutch pedal, and when you shift the unit in direct drive you should feel a definite engagement. The higher the gear you choose, the more pronounced the direct engage will be. Whenever you get your tractor assembled, I would be interested in the extra parts if you're going to sell them. My e-mail link is provided--Thanks.
INCase
04-15-2005 09:34:47
 Re: general questions 800 and 730 in reply to Patrick (Mich.), 04-12-2005 21:41:24
Thanks Patrick. I sent you an email and opened mine up. Let me know what you may need/want.
