50 VAC
cleatusj
04-10-2005 13:28:01
Any suggestions on where to locate exhaust manifold for '50 VAC. The one that came on my tractor has more holes than the last sheet of expanded metal I bought. Repro would be ok.
cleatuej
04-20-2005 18:53:47
 Re: 50 VAC in reply to cleatusj, 04-10-2005 13:28:01
I've welded it and it works, as in I cannot see or fill any leaks.
Check the link to see results.
Mark L.
04-14-2005 05:01:49
I have some Case V series manifolds. Don't know what they fit. If you can email a picture of yours, I will go through the pile of them, and let you know.
C. Amick
04-11-2005 09:16:45
I haven't heard of anyone making reproduction ones, yet. Have you tried posting in the classifieds on this site?
cleatusj
04-11-2005 20:33:51
 Re: 50 VAC in reply to C. Amick, 04-11-2005 09:16:45
I'm going to try some new rods. Hope thy work at $25.00 for 1/2 lb.
C. Amick
04-12-2005 04:29:39
 Re: 50 VAC in reply to cleatusj, 04-11-2005 20:33:51
I've always used a brass rod and a torch to repair cast iron. Some people use a cast iron welding rod with a torch. There should be a lot of these used manifolds lying around because there were a lot of VAC's made. I know of some used parts suppliers that might have one if the welding job doesn't work out ([email protected]).
