Case 1816 charging/wiring
dogtowndhm
04-10-2005 07:06:42
I recently purchased an 1816 skid loader which works great ewxcept the charging syst. isn't working. Some one has added a seperate switch for the ignition. The origional switch runs the fuel pump and starter. I found several wires cut off in the eng. compt. I don't know if the charging system is inop. or not connected properly. Does the shop manual include a complete wiring diagram. Or does some one have a diagram to sell or share?
Eric Amundson
12-11-2005 12:01:59
 Re: Case 1816 charging/wiring in reply to dogtowndhm, 04-10-2005 07:06:42
If you e-mail me, I will send you pages out of the operator's manual that might help. It shows a simplified version of both the early and late production wiring diagrams.
Ray Clugston
01-22-2008 05:27:09
 Re: Case 1816 charging/wiring in reply to Eric Amundson, 12-11-2005 12:01:59
I have two wires going from the ign. switch to the coil, brown & green. Brown is powered. Is green ground.
