amp meter
paulver
04-09-2005 19:01:37
Does anybody out there know how to hook up an amp gauge on a 1968 Case 430 diesel? It was added on some time ago, but it was disconnected before I got it. I purchased a new one to replace it. The two terminals are marked +L and +B. I know that one of them has to connect to the ignition switch, but I"m not sure where the other goes.
Thanks in advance.
Paul
Jerry W
04-09-2005 20:35:36
 Re: amp meter in reply to paulver, 04-09-2005 19:01:37
I do know exactly how a 430 Case would have done it but in general one terminal is hooked to the big lead coming from the generator or alterator (I would guess that it would be the L terminal). Now off of this same terminal would be all wires that could draw any current except the starter circuit.
Off of the second terminal (probably the B) a single wire should go the hot side of the battery (+ if system is negative ground and - if system is positive ground) and it may go to the switch but not required.
If it shows charge when it in fact is discharging - interchange the terminals.
In this way only the generated electricity above and beyond the electricity consumed is measured by the gauge.
Jerry
jdemaris
04-10-2005 19:59:37
 Re: amp meter in reply to Jerry W, 04-09-2005 20:35:36
Everything you wrote/said is fine - except, if he's got the intake-manifold air heater, he does NOT want to run the power for that through the ampmeter. It draws around 60 amps.
paulver
04-11-2005 04:26:52
 Re: amp meter in reply to jdemaris, 04-10-2005 19:59:37
I do have the manifold heater. What do I have to do to connect the gauge correctly?
Jerry W
04-11-2005 20:23:29
 Re: amp meter in reply to paulver, 04-11-2005 04:26:52
You just ignore the start circuit and the manifold heater circuit when wiring the amp gauge because they draw more than the gauge can handle.
You would wire the manifold heater direct from the hot battery post to the manifold heater switch (probably not ignition switch). You would by pass the ignition switch too I believe unless you would have a solenoid or a relay in which case the control circuit wiring might go thru the switch and the amp gauge but not the main power circuit wiring.
Your best bet is to buy a manual that directs fits your tractor.
Jerry
