700 case
jds
04-09-2005 08:21:24
How many 700 diesel case tractors were made? I found one with a wide front but the engine is stuck. Is it worth looking into?? Are they a dime a dozen or is this really something?
Tim in New York
04-10-2005 16:50:17
 Re: 700 case in reply to jds, 04-09-2005 08:21:24
I paid $800 for mine, not running, but engine was loose. Probably have a problem with one or both heads. They"re supposed to be pretty good tractors when running, hope I find out someday. Number on my tag is 701-B. FYI - most parts other than sheet metal are interchangeable with the 400 series tractors of 54?-57.
Tim in NY.
dctom
04-10-2005 11:21:58
there was a total of 3330 700's built of verious modles I think the 711-b was the diesel and there were 980 of them, only built for two years 57 and 58
discount dave
04-09-2005 20:17:30
If you can get it for 800.00 or less you could sell parts and double your money. Peter Leterneou was not right on alot of the information in his book.
mikes'600
04-09-2005 14:35:51
I think glen's production numbers are alittle low.I have a 7oo LP, which i think case produced 250.
Glenn/Mn
04-09-2005 08:36:12
there is many versions like 701B,710B,711B I believe you are talking about a 700B. the production numbers very but for the 700B it is 60 in 1958 and 83 in 1959. A good cheap book worth getting for this information is by peter letourneau titled illustrated buyer guide on Case tractors.
N
04-10-2005 01:25:03
 Re: 700 case in reply to Glenn/Mn, 04-09-2005 08:36:12
O.K. guys, two questions -
Are all 700 series tractors somewhat rare, or just 700B? (barring 730 series tractors, of course)
Do you guys know of anywhere on the web that tells how to decode what the last two digits mean?
My grandmother has a 700 series deisel with a narrow front, and I never imagined that it was rare.
Neil
caseman-d
04-10-2005 16:58:19
 Re: 700 case in reply to N, 04-10-2005 01:25:03
Case only made the 700 in the B series. What you go by is the model on the tag on the rh side of instrument panel. My IT manual gives breakdown of identifing the different models.
caseman-d
N
04-10-2005 18:19:11
 Re: 700 case in reply to caseman-d, 04-10-2005 16:58:19
Thanks for the help.
I should clarify. I understand that Case only made the 700 in the B series. What I was wondering, is whether it was just the 700B that was rare, or if others, such as the 701B, the 711B, etc., were rare.
Neil
caseman-d
04-10-2005 20:30:31
 Re: 700 case in reply to N, 04-10-2005 18:19:11
I wouldn't consider them rare but more as a low production tractor. One may consider the 703 and 713 as a rare tractor. Production figures on the 703 High Clearance diesel is roughly 6 in 58 and 24 in 59. The 713 High Clearance gas production was 8 in 58 and 11 in 59. These were the lowest produced models in the 700 series. Rare doesn't always mean a well sought after tractor. All depends on the collector as to what there worth.
caseman-d
