VAC S#
PaulL
04-08-2005 09:02:06
A friend has a VA that is missing its serial number plate. Can the number be found elsewhere on the tractor? We've looked on the block like on SC's and DC's but haven't found anything. Also, what differences are there between VA's and VAI's? In photos, they look very nearly the same to me.
Wheat Straw
04-08-2005 19:25:05
 Re: VAC S# in reply to PaulL, 04-08-2005 09:02:06
Paul,
the va has 28 inch rears and the vai 24' typicaly. The va is simply a vac with a standard tread front axil per the other posts.
Wheat Straw
PaulL
04-09-2005 07:39:39
 Re: VAC S# in reply to Wheat Straw, 04-08-2005 19:25:05
Thanks for the help guys.
Jerry W
04-08-2005 11:23:36
To my knowledge there is nowhere on a VA where a duplicate of the serial number can be found. On a DC/SC/LA it can be found on the back engine flange by the starter. (if I remember right)
VAI's usually have a heavier front axle and sometimes have faster 4th gears. Some VAI's also have a more "truck" type hub on the front axle than a VA. Some VAI's also have a squared off front steering bolster to which a loader and a crank driven hydraulic pump could be mounted.
I also have been told that the VAI's with the road gearing have a conventional gear shift pattern of 1 3 instead of 1 2 but I have not seen this.
2 4 ----- ---- 3 4
Lots of little differences.
Jerry
Arthur
04-08-2005 11:15:58
You can tell the diffrence from a VAI, and a VAC by looking at the front axle. If the axle is 1 1/4" thick, it's a vac...Bigger than 1 1/4" thick, and it's a VAI. Also if it has a horn under the hood, it's a VAI, but sometimes the horn is missing....There is a motor number on the carb side, by the torque tube end up just below the valve cover, but that won't tell you what model the tractor is.
Arthur
04-08-2005 11:17:51
 Re: VAC S# in reply to Arthur, 04-08-2005 11:15:58
Sorry I meant VA , not VAC...Both models have a non-ajustable wide front....
