Case 1394 4WD Three point linkage.
DavidP, South W
01-11-2006 11:14:38
Hi,
We have a UK Case 1394 4WD Dual pump. The three point linkage went down and would not come up again. Have checked oil and filter etc. There is oil coming from the front pump outlet. The spool valves are producing just over 2000 psi and have no problem tipping a trailer. Have followed the quadrant lever linkage down to the casing on the front of the rear axle and see two hook shaped levers that look as if they should be permanently in contact. The lever on the axle remains about vertical irrespective of the position of the quadrant lever and the corresponding movement of the other lever. My question is whether the 'axle' lever should follow the 'linkage' lever and maybe supply oil to the cylinder. I have tried to prise the lever with a little force but it did not move. Any thoughts or ideas on the source of the problem would be very much appreciated.
Thanks
David P
