LA gas tank
Ande
09-17-2006 17:43:13
My "LA" has not been running in 5 years, wondering what procedure I should do before startup.
My thoughts are to rinse out the gas tank,but with what,just more gas?Should I worry about the valves stuck? Going to change oil and filter.
Ande
Walt Davies
09-17-2006 19:14:34
 Re: LA gas tank in reply to Ande, 09-17-2006 17:43:13
I would put some light oil in the cylinders and let that stand over night to soak in to the rings. Then get new plugs replace any bad plug wires make sure that you get the copper core (you can get them at NAPA). Check mag for spark clean points and any corrosion. Now turn the engine over by hand with the crank and the plugs out. Once it turns over freely then replace plugs and hope for the sound of the engine starting. Run at low speed ubtil the oil clear out and the engine runs without smoking. You should be Ok afte that to run normally.
Walt
Ande
09-18-2006 06:18:44
 Re: LA gas tank in reply to Walt Davies, 09-17-2006 19:14:34
Walt
Thanks for the good info,couple question"s back at you,when you talked of light oil,would spraying some WD40 in each cylinder qualify for light oil or something a bit heavier? How about that old gasoline,there isnt much in there and it does not look good,would you just rinse with new gas?
Ande
JGarner
09-18-2006 07:21:37
 Re: LA gas tank in reply to Ande, 09-18-2006 06:18:44
Buy a quart can of Gumout at NAPA and rinse the tank with that after a fresh gas rinse. The Gumout will clean out any varnishe build up.
Ande
09-18-2006 07:23:39
 Re: LA gas tank in reply to JGarner, 09-18-2006 07:21:37
Great thought will pick some Gumout for the old girl
Ande
Walt Davies
09-17-2006 19:18:29
Forgot go to this web site to see the Magneto manual it will help you a lot.
Walt
http://laanderud.com/case/magneto/
