VAC TSX749 carb???
Eric Foster
04-07-2005 07:55:08
All,
I've had several problems with the carb on my '50 VAC, so I went online to look for a rebuild kit. When I entered the TSX749 number, the only models were the two-tones (400 etc.). Does my tractor have the wrong carb, and if so, could this be some of my problem.
The maintenance manual has a TSX carb that looks very similar to the one I currently have installed.
Can I just get a kit for this one? Where do I get one (all I'm finding is rebuilt ones for $150...too rich for me right now).
Sorry for the long post,
Eric
Eric Foster
04-11-2005 07:59:16
 Re: VAC TSX749 carb??? in reply to Eric Foster, 04-07-2005 07:55:08
All,
Thanks for the input. I'd really like to get another TSX carb. I've spent too much time reading up on this one to swap over to the Zenith.
Would I be able to get a core charge credit on a rebuilt TSX114 if I sent them the 749??
Glen in TX
04-08-2005 23:58:49
Eric, My M/S-Zenith book shows the TSX749 to be OEM for the Case 400B,500B,540,541,&600B. Probably jetted wrong for your smaller VAC with 124 cu. in. engine. The 400B was 251 cu. in and the others were some smaller so who knows what it really could be jetted for. Showing these Marvel Schebler carbs used on the VA series: TSX114, TSX253,TSX597, & TSX663. Also Zenith replacements are 12522 & 14544. Both of the Zeniths are still available new. Kits are available for the TSX series and I have those if you need one but none of the carbs right now.
gary case
04-09-2005 16:27:34
 Re: VAC TSX749 carb??? in reply to Glen in TX, 04-08-2005 23:58:49
tsx114 kits are13.99 needle and seat 6.29 and the float is 16.69 available lots a places
Lincoln
04-07-2005 16:48:35
My Case 611B has a TSX749 carb on it. Acording to the parts book this is correct. I would guess it is not the right carb for your VAC.
F-I-T
04-07-2005 09:19:04
third party image
Eric:
I chased carb problems like yours on my '50 VAC. I finally found that I had the wrong carb. I believe the original carburetor form the factory was a M/S TSX-114. I had a mis-performing TSX-112. I later opted to install a NEW Zenith that I bought from this site and I must say that it bolted right on and adjusted nicely. It really made the bnewly over-hauled engine sing. I've had it on my dynamometer since then and fine tuned it, but I was not far off.
Any way, a TSX-114 is what you would be looking for. I'm not sure how much different the -749 is, but some one here will probably be able to provide you with strict numbers and where used info.
Frank
