Using Liquid Drano in tractor radiator
okla kansan
04-06-2005 15:52:37
friend at work told me about it. Wanted to ask u guys what you thought. Thanks
Keith-OR
04-07-2005 23:29:14
 Re: Using Liquid Drano in tractor radiator in reply to okla kansan, 04-06-2005 15:52:37
I agree with most of the other post on not using Drano, which has lye in it, I think I would use Muriatic acid, since this is the main ingrediant in lime-a-way and CLR. I periodically run it through my steam cleaner to remove hard water deposits such a lime and rust. Follow directions on container.....Keith
hay
04-07-2005 12:02:41
like the others said, i would not use drano or any lye based product, but maybe something like CLR (calcium, lime, rust) remover would help. might need several containers of it to do any good though. i think the best idea would be to get the radiator professionally cleaned and rodded out. that way you know for sure it is clean and does not leak. who knows what will happen with some of the "cleaning" products out on the market.
REDEYE
04-07-2005 07:01:10
dont use draino. it contains lye which is very corrosive to some metals. I know aluminum is one and perhaps coper, lead and potentially others I dont remember anymore. anyhow some solders contain AL and you run the risk of eating away your joints if you use lye. and if i remember right from chemistry class it would be better to clean with a mild acid, assuming that you have mineral deposits in your rad. i know that the stuff we use to clean the hard water deposits off the shower "the works" has phosfuric or phosulmaic acid in it and it does a good job. another weak acid you can try is acetic, which is basically vineger. however, dont use vineger as it is too weak. "industrial" vineger can be purchased from some garden centers as it is an "organic herbacide."
Coloken
04-07-2005 06:51:01
Think that would be going the wrong way. Most radiators have hard water/lime. Need an acid to loosen that. Course if it is full of hair---
Dennis/Ohio
04-07-2005 02:25:58
I tried LimeAway on a heater core, I don't think it helped. I see alot of brass sink traps, galvinized pipe & cast iron pipe on older homes rotted through. I was always told drain cleaners did it? The organic explanation makes sense, I know it will burn my hands.
Best wishes, Dennis..... ..
wayne2
04-06-2005 21:50:00
I've used low sudsing auto dish washing powder without any ill effects. Can't say about drano.
Camboted
04-06-2005 18:43:26
I think that Draino is a product that consumes organic material, like Lye. I've used it and it is great for hair, grease and that kind of thing, but all the DC radiators I have rodded were plugged primarily with rust chips. I don't think it would be that effective on them because they advertize it as "safe to plumbing". I guess there is no harm in trying, the only concern I would have would be the waterpump seal.
