Drive Chain Adjustment 1951 DC-3
Chris Hibbert
04-06-2005 12:03:03
I was reading on a post about someone recommending adjusting the drive chains. I was curious how one would go about doing that? It looked to me that you could only remove a link to adjust it and those links are so big. How else would you adjust the drive chains and could anyone tell me what sort of drive behavior would trigger needing adjustment?
CASEPOWER
04-06-2005 12:39:29
 Re: Drive Chain Adjustment 1951 DC-3 in reply to Chris Hibbert, 04-06-2005 12:03:03
Adjusting the drive chains requires you to remove the shifter top housing, if your tractor has a PTO. You can than remove the back cover were you will find the two square head bolts that are tightened to take up slack. Make sure you loosen the axle housing nuts first. I do have a picture with the rear housing removed. The adjustment bolts are visible in the picture. Let me know if you would like me to post it. The links are so big, I doubt one could be removed and the chain still be long enough, unless you went with smaller sprockets.
53DC
04-07-2005 05:27:53
 Re: Drive Chain Adjustment 1951 DC-3 in reply to CASEPOWER, 04-06-2005 12:39:29
If you could post the picture it would be appreciated. Thanks
CASEPOWER
04-07-2005 10:18:34
 Re: Drive Chain Adjustment 1951 DC-3 in reply to 53DC, 04-07-2005 05:27:53
third party image
Here is a CO. Everything you see is the same as a D series, except the brake pedals.
