Wondering if you all would be willing to give me a hand with a question.I have a 188D in a Case skid steer loader (1835B) that was recently torn down to rebuild. Went ahead and had my diesel machine shop check the head, reseat valves and get that all right. I then proceeded to resleeve the engine, new pistons and rings and continued a "normal" rebuild. Everything was seemingly very good and we put the engine back in the machine and fired her up. Had a problem with lack of rpm, not running well and huge amounts of smoke. We were sure we had the timing lines matched up between crank,cam and fuel injec gears, so we went ahead and turned back the injection pump to its limit and it cleaned up nicely and is able to rev to probably 85% of its previous level (before rebuild). We went ahead and let it run for about 10 hours at 45~55% throttle in 3ish hour increments. Everything was seeming very nice and smooth, but we still only had about 85% of our previous throttle. We decided to go ahead and take it out on a little test. Fired it up from (almost) cold and it came right to life. A little darkish white smoke, but not bad at all. Started off and put the bucket down to move some gravel and it had seemingly gobs of power, no trouble. A few seconds latter (about 30~45 seconds after turn on) the engine slowed down a little bit in revs, but more importantly if you put it under any load, it almost choked out. Played with the fuel injection pump some more, made sure all the injectors were getting fuel, no leaks, etc. Fired it up again, and same thing. Great response for about 30ish seconds. Out of curiousity I turned the machine off, waited about a minute and cranked it up. Same thing happened. Great response, this time for 20~30 seconds, then it slowed down a little bit, started smoking a little more, but when under any load it almost conks out, similar amount of power to what you get when in idle. Is there anyone here who could possibly lend me some knowledge on this matter? Thanks, Karl P
