CamboTed - VAC head work
Augie
04-04-2005 21:40:13
Got the head back Friday evening. They only took another .065" off the deck surface, for a total of .125" I'd hoped they would go a little farther with that, but since we're planning to use this head on a 200 + cid crankcase they thought it would be a good idea to leave a little more meat in the head.
Picked up 20psi cylinder pressure at cranking speed over what it had prior. I expect another 5-10psi after a proper rocker arm adjustment.
Fired it up tonight and it sounded pretty good. Now I just need to get it on the dyno and do some tuning...
Camboted
04-04-2005 22:46:43
 Re: CamboTed - VAC head work in reply to Augie, 04-04-2005 21:40:13
Augie, thanks for the information. Did you have to raise the rocker arms?
Augie
04-05-2005 05:53:05
 Re: CamboTed - VAC head work in reply to Camboted, 04-04-2005 22:46:43
Didn't have to shim the rocker stands. Rocker arm tip-valve stem contact looks good.
Sure was nice to hear it running again.
