Model L float level
dlp
04-04-2005 17:25:11
What is the float level measurement & how is it measured on the Zenith carb?
DCDENNIS
04-06-2005 18:47:50
 Re: Model L float level in reply to dlp, 04-04-2005 17:25:11
dlp;I just installed a tisco kit C553in my LAI and the instructions say install floot valve assy and new gasket, then set carb on level with manifold opening face down and measure 1 3/4, plus or minus 1/16 in. from machined surface on body to point of float. if necessary, bend float arm next to float to obtain correct measurement. do not bend float hinge. be sure float moves freely. hope this helps you out, this should be good for LA and L CASE zinith 6799and 8744 carbs I did not have to adjust my float, and the engine runs real good.if you need any more imf. please ask I have the servics instructions right hear. DCDENNIS
