VAC dying when hot
JC CASE
04-04-2005 16:49:59
Just got this 44 Vac, it's a cherry. But it keeps dying when hot. Changed coil out. Is there anything else to try or ideas. Thankyou JC
Keith-OR
04-04-2005 19:46:42
 Re: VAC dying when hot in reply to JC CASE, 04-04-2005 16:49:59
JC, check the inlet above the sediment bowl, where it screws into the tank. Mine gets plugged there and have to remove the sediment bowl and run a wire up into the tank. Will work fine fore couple of weeks then will have to do the same thing again. I have even had the tank off and cleaned it as best as I can...HTH Keith
Joe (Wa)
04-04-2005 20:10:45
 Re: VAC dying when hot in reply to Keith-OR, 04-04-2005 19:46:42
Hey Keith, reminds me a VAC I bought with a couple inches of crap in the tank. It had a rubber hose for fuel line. I cut the hose & put in a plastic tee and run another hose up by the steering wheel.
Drive a 1/4 mile it would start to sputter, blow in the hose until I hear bubbles in the tank ... drive ... choke ... blow ..... drive ... choke ... blow ... 6 miles never did die, finally made it home.
Joe
Keith-OR
04-05-2005 21:44:23
 Re: VAC dying when hot in reply to Joe (Wa), 04-04-2005 20:10:45
really good one Joe...Almost fell out of my chair was laughing so hard...LMAO
Keith
CASEPOWER
04-04-2005 17:19:33
Try changing the condenser. Also make sure it is not a fuel problem. It could be using the fuel in the carb bowl and not filling back from the tank in time to keep up.
JC CASE
04-04-2005 18:09:38
 Re: VAC dying when hot in reply to CASEPOWER, 04-04-2005 17:19:33
Points and condenser are new. About the fuel not filling in time, it will restart with choke but once let out clutch it dies, give it 5 mins. it will run again for maybe 5/6 mins.
CASEPOWER
04-04-2005 19:26:38
 Re: VAC dying when hot in reply to JC CASE, 04-04-2005 18:09:38
You need to start by checking the flow from the tank. Make sure you have a good flow from the line at the carb. There is a good chance it could be trash just before the needle. A good cleaning and maybe a kit should solve it.
Joe (Wa)
04-04-2005 19:51:03
 Re: VAC dying when hot in reply to CASEPOWER, 04-04-2005 19:26:38
Also check the gas cap vent is not plugged. Drive it w/o the cap to check.
JC CASE
04-05-2005 19:05:15
 Re: VAC dying when hot in reply to Joe (Wa), 04-04-2005 19:51:03
Thankyou oh wisemen! line from tank was restricked. Runs like a champ. Thanks again JC
