How do you bleed the fuel system on a CASE 350 B?
Steve Smith
04-04-2005 12:52:38
The diesels which I have worked on in the past have all been equiped with a hand pump on the fuel injector pump. After changing out the filter or any thing to do with fuel system you could break the line at the injectors and use this hand pump to push fuel through the system and bleed the air out. I can't locate any such pump on the engine of the 350 B. I don't know if this will help but the fuel pump inscriptions on the ID plate are, as best they could be read by and old guy with bi-focals useing a small mirror,
BOOSA MASTERH
DBS43TJN3708 2000
2750880 A 154566
If there is no hand pump on the fuel system then what do you do? Just turn the engine over till fuel is comming out of the opened infector fittings? This method seems like it would be kinda hard on the starter motor. Thanks in advance for your input,
Steve Smith
george md
04-04-2005 22:55:43
 Re: How do you bleed the fuel system on a CASE 350 in reply to Steve Smith, 04-04-2005 12:52:38
Steve,
From one old guy to another , relax. That system is gravity from the tank, bleed the filters and I like to bleed the line from the filter to the pump at the pump end. Loosen a couple inj lines , crank a few turns and you should have fuel at the injector , tighten loose
lines and go play in the dirt. I have a 450 and
a 580B , same set up.
george
