Case SC Brakes?
Dixieland
04-03-2005 10:14:58
I am just finding out a few things about my first Case tractor...I have a 1953 SC but no brakes unless I stand up but that ain't much. What is involved in replacing or repairing the brakes?...Thanks...Dixieland
C., Amick
04-04-2005 04:35:01
 Re: Case SC Brakes? in reply to Dixieland, 04-03-2005 10:14:58
If it is the same braking system that is on the older SC's, it is a ramp ball type brake. The steel balls get rusted and don't want to roll. Email me when you get the brake off the tractor, if you want help ([email protected]).
Dixieland
04-04-2005 17:06:20
 Re: Case SC Brakes? in reply to C., Amick, 04-04-2005 04:35:01
Thanks C...I will be too busy the next few days but I sure may take you up on that offer...Dixieland
jstpa
04-03-2005 11:37:33
If it's like my 52, you pull the four bolts out of the drum, there's one on each side, and there are your brakes.look and see if they are soaked in oil, if they are you'll probably have to replace the differential seals. You may also just need to adjust them. Tighten the nut at the bottom of each brake pedal, I think my manual says you should have 1 1/2" of pedal movement. It could be other things but I would start with these 2 first. good luck, jstpa
Camboted
04-04-2005 04:57:58
 Re: Case SC Brakes? in reply to jstpa, 04-03-2005 11:37:33
If your seals are gone you really need to polish the shafts or you will soon tear out the new seals.
Dixieland
04-04-2005 17:04:34
 Re: Case SC Brakes? in reply to Camboted, 04-04-2005 04:57:58
Thanks Cam!
Dixieland
04-03-2005 13:37:57
Thanks J....that sounds like a good start...am I gonna need new gaskets when I remove the covers?
Glenn F.
04-03-2005 14:16:46
 Re: Case SC Brakes? in reply to Dixieland, 04-03-2005 13:37:57
No gaskets there as that housing is dry and only serves as a brake drum. Glenn F.
