580 CK Pump shaft gear
Greasey Hand
04-01-2005 19:46:30
On the Shuttle Pump #A37570 That drives off the converter, The drive gear has wore the shaft some so it is loose & key is shot, Any good way to fix it, A new pump is 750. today, price goes up on Monday to 800. & drive gear is 320.28 TO MUCH!
Or does any one have a good gear & main shaft for the pump, Thanks.
Greasey Hand
04-03-2005 06:38:59
 Re: 580 CK Pump shaft gear in reply to Greasey Hand, 04-01-2005 19:46:30
Does any one have a good A40878 Its the bolt on pilot that goes on the converter & into the flywheel, Mine is wore on the inside where the locking sealing ring seals.
Than I need the input shaft & main drive gear for the shuttle pump that sits under the first cover.
There is no way to fix these parts & make then work & last is there?
Can you guys that have worked on these things help me out I would like to get this tractor together. Thanks
jdemaris
04-01-2005 20:39:23
You can't just build up the shaft a little and put in a new key? Key failure is common on the shuttle pumps for the 530s and 580s, I've fixed a lot of them. The price you mention sounds insane, but I guess that how parts are getting to be. I just tried to buy the two o-rings where the shuttle pump connects (A7075) and Case says they are no longer available. I had to match them with some John Deere flat o-rings.
Greasey Hand
04-05-2005 18:11:32
 Re: 580 CK Pump shaft gear in reply to jdemaris, 04-01-2005 20:39:23
I just got 2 of those pump O Rings today from Case
no problem.
jdemaris
04-06-2005 05:44:22
 Re: 580 CK Pump shaft gear in reply to Greasey Hand, 04-05-2005 18:11:32
What is the new part number for the flat o-rings? My local industrial dealer could not find a good number for them. This did not make much sense since the pump and parts are available.
Greasey Hand
04-06-2005 18:38:06
 Re: 580 CK Pump shaft gear in reply to jdemaris, 04-06-2005 05:44:22
jdemaris;
The part no of the pump O rings is 51200848.
There is 1 in each pack. 2.70 each.
There is another no WH003E They might need it to.
Good luck.
jcmarleau
04-01-2005 20:07:51
May have a good gear and shaft will check tomorrow my e mail is [email protected]
Greasey Hand
04-06-2005 18:58:26
 Re: 580 CK Pump shaft gear in reply to jcmarleau, 04-01-2005 20:07:51
Does any one have a good A50962 (Crank Pulley)
For a 159 Gas motor & the A35673 Nut to hold it on.
Also need a Dist W/Tack drive.
A A40878 Pilot on the converter. Thanks
Hope some one can help on these parts.
