case 530 diesel lubes?
gary case
04-01-2005 05:13:31
need a good advice about fluids in motor(what wieghts)rear end,trans duel range. has lever on left that looks like shuttle shift. push forward and all gears work, pull back and it's taking it out of gear.is this right? haven't got any manuals on it yet please advise. thanx in advance, gary
wayne woodrum
04-02-2005 10:36:00
 Re: case 530 diesel lubes? in reply to gary case, 04-01-2005 05:13:31
the leaver on the left is the hand clutch the leaver on the right is tripple range. i would use 15w40 in the diesel
preachermannn
04-02-2005 08:47:49
We have a Case 530 my Dad bought in 1964. The lever on the side of the tranny is the high low range on ours. All the way forward is the high range. All the way down is the low range. The middle is "neutral." Put it in the middle and the tractor will go no where. We always used Valvoline 10W40 in the motor. Although recently we have started using Delo 15W40. Rear end we use 85W140. Our 530 does not have a three point hitch.
gary case
04-02-2005 15:35:29
 Re: case 530 diesel lubes? in reply to preachermannn, 04-02-2005 08:47:49
thanx wayne and preahermann! mine does have the 3pt. now i dont know if this was optional or ive got something different. also wayne mine is dual range,maybe wrong. i've onlyhad the tractor for a day. so cold out here i just said i'll play tommorow. haven't got any books on it yet. i drained all the fluids and want to try to find the hyd. filter/s.
waynewoodrum
04-02-2005 17:14:17
 Re: case 530 diesel lubes? in reply to gary case, 04-02-2005 15:35:29
the hyd filter is under the fuel tank on the left hand side up from your hand clutch lever on top of the hyd pump 4 bolts hold the cap on and a big hyd line in the center of the cap that goes to the lift if your tractor has eagle hitch it won't have the hyd line the filter is inside the hyd pump cover goodluck
gary case
04-03-2005 06:52:23
 Re: case 530 diesel lubes? in reply to waynewoodrum, 04-02-2005 17:14:17
thanx wayne! going to check it out this morning.soon as i have breakfast and get my carharts on. 24 this morning. man, come on spring.
waynewoodrum
04-03-2005 07:23:06
 Re: case 530 diesel lubes? in reply to gary case, 04-03-2005 06:52:23
24 that is cold, its about 50 here in KY
