Horse power of VAC ?
Steve R
03-31-2005 18:19:44
I have a 1948 Vac. I would like to know what the stock horsepower is, and what it is with 3-3/8"
pistons? Steve R
Augie
03-31-2005 20:04:06
 Re: Horse power of VAC ? in reply to Steve R, 03-31-2005 18:19:44
A little bit of work on the cylinder head, a good tune-up, and one of Don L's 3 7/16" piston/sleeve sets should get you to around 30hp.
Camboted
04-01-2005 02:59:40
 Re: Horse power of VAC ? in reply to Augie, 03-31-2005 20:04:06
Augie, what do you do to the head, just shave it?? How much can you cut off?
Augie
04-01-2005 09:12:43
 Re: Horse power of VAC ? in reply to Camboted, 04-01-2005 02:59:40
All I did on that go-round was take .060" off the deck and blended the port entries to match the gasket. Forgot to mention that I removed 3 of the 9 ball bearing governor weights, which makes the engine react much quicker to load changes.
I'll have more info soon. Head is in the machine shop and should be just about finished. Installed larger valves, full port job, flycut the chambers to unshroud the intake valves, more shaved from the deck.
Wheat Straw
03-31-2005 19:34:48
Steve,
Nebraska tests put the gasoline tractor at about 20. Dad put a super power kit in his and it pumped it up pretty good. Seems to me like they said it would add about 15% to the horsepower. Gave it about 23 or so.
Wheat Straw
Camboted
03-31-2005 19:45:27
 Re: Horse power of VAC ? in reply to Wheat Straw, 03-31-2005 19:34:48
Somewhere I read that when they first put in that little Continental engine they had the rpms set a couple of hundred higher and had to back it off because it was close to overpowering the SC. I know one Nebraska test came back about 23hp.
Wheat Straw
03-31-2005 20:05:02
 Re: Horse power of VAC ? in reply to Camboted, 03-31-2005 19:45:27
"Full Steam Ahead" has a story about that. VC had the continental and was a little bigger than the vac. Enginers designed the vac with a six speed and 1650 rpm and a little more compression. Clausen killed that dealto protect the sc. Wow, what a tractor that would have been.
Hey combo, I'm trying to modernize my vac fleet. I have one bought with the eagle hitch but some parts are missing. Sent a check to a guy in ohio today for the draft arms and the linkige from the draft arms to the rock shaft links. They don't have the latches in them. He said nobody makes after market latches for the VAC. Would you consider making them. I'd try to be your first customer.
Thanks
Wheat Straw
Camboted
03-31-2005 20:11:11
 Re: Horse power of VAC ? in reply to Wheat Straw, 03-31-2005 20:05:02
Wheat straw, let me look into it. The question is always quantity. The big cost for us is mold building and set up. We'd have to make them out of cast steel. Not saying I won't do it. I've got a VAC here now so I'll give it a try.
Wheat Straw
03-31-2005 20:41:42
 Re: Horse power of VAC ? in reply to Camboted, 03-31-2005 20:11:11
Combo,
Thanks, I figured volume had something to do with it. I can't even emagine how you would begin on a project like that. Sounds interesting. Thanks for the thought.
Wheat Straw
mj
04-01-2005 07:19:20
 Re: Horse power of VAC ? in reply to Wheat Straw, 03-31-2005 20:41:42
I'll try to be your SECOND customer.
