CASE SC MAGNETO questions
vineyard Matt
03-31-2005 17:13:27
Well I had some problems earlier with what i thought was a kill switch problem but it turns out it wasn't that. I now have no spark coming from the magneto and I took the mag off to check the points and it looks like some moisture got inside and there is some surface rust on the points my question is any recomendations? fileing them?, can you buy just new points?, and if I do need a new mag can you still get a mag from a case dealer? I guess any help here would help Thanks,
Matt
Glen in TX
03-31-2005 21:46:08
 Re: CASE SC MAGNETO questions in reply to vineyard Matt, 03-31-2005 17:13:27
Hi Matt, Take care of the points like John said and if still no fire some of us have coils, condensers, and new gaskets. New points haven't been made in years and getting harder to find.
John Saeli
03-31-2005 17:48:40
Hey Matt: Some of us sell used Mags. None available from CASE. Carefully dry that mag out. I like to take all the connections apart & clean them. Use very, very fine emery paper to clean the points. Set them at .015. Keep us posted.
Preachermannn
04-02-2005 08:52:52
 Re: CASE SC MAGNETO questions in reply to John Saeli, 03-31-2005 17:48:40
I too have filed and reset mag points. Filed mine with an emery board, blew everything clean with carb cleaner, (the kind you buy in a spray can) and then sprayed a little WD-40 in the cap and around the points to drive off and keep away any moisture, (the "WD" stands for "Water Displacement"). The last new mag we bought was about 25 years ago. And wouldn't you know it, that was the one tractor my Dad got rid of!
