D, 1950, Water Temp Sender Location
Adam Whitson
03-31-2005 16:25:40
Old temp sender and cable is laying on top of the head on the left side, between the valve cover and manifold. I cannot locate the port that it should screw into. I have check the top of the head, cast water neck, even the radiator overhang.
P.S. Im not blind.. . . ;)
Preachermannn
04-02-2005 08:58:17
 Re: D, 1950, Water Temp Sender Location in reply to Adam Whitson, 03-31-2005 16:25:40
Howdy, We too have a 1950 Case D. (Ours is a D.O. model). The temp sender location on ours is underneath the top of the radiator housing. I'm sure yours is the same. Look on the backside, (toward the front of the motor) of the big cast iron water reservor. Beneath that is a "L" connector. The temp sender is in that "L" connector. It's above the fan/water pump, to the carb/manifold side of the motor, (the left side if you're looking at the tractor from the back).
