Case vai ---hydraulic fluid ..fill plug..you got t
Gregg in ohio
03-31-2005 11:47:11
my case has developed a minor problem..the 3point continues to rise even though the lever is in the down position very slowly i can make it go down by standing on it or shutting off the tractor,,heres another thing with the fill plug removed there is a big hunk of rubber or material sticking out just below the filler hole..dont think its supposed to be there.its where a plate is with mounting bolts..any ideas..i can handle any mechanical job just dont want to take anything apart wrong..thanks gregg in ohio+
Joe (Wa)
03-31-2005 14:38:35
 Re: Case vai ---hydraulic fluid ..fill plug..you g in reply to Gregg in ohio, 03-31-2005 11:47:11
Gregg, The thing floating in the oil is probably part of the return oil filter element. If the element gets plugged, the return oil pressure will rise and blow a hole in it.
When you put the lever in the raise position, you are shutting off the control (by-pass) valve that normally will be circulating the pump output back to the reservoir. When the by-pass valve is shut the oil pressure goes to the piston via the lift check valve and raises the draft arms.
When you put the lever back to neutral, the by-pass valve opens to recirculate the pump and the lift check valve closes, hydraulically locking the piston. If the return is restricted enough for the pump pressure to overcome the weight of the draft arms + load, the lift will continue to rise until the piston bottom out.
When you stop the engine the pump pressure drops to zero but you still have a hyd lock on the piston. When you move the lever to lower position, the release valve opens dumping the oil on the piston into the return line. If the return is restricted you are using force other then gravity to drop the draft arms.
Overgreasing the rock shaft bearings or an accumulation of grease over the years is generally the culprit. The grease accumulates under the piston and is pushed back to the torque tube through the leak-off/vent tube on the lower right side of the cylinder housing. If the hyd oil is not changed regularily, the grease in the torque tube is picked up with the oil and circulated blowing a hole in the filter.
The filter element is under that 4 bolt flange located just under the fill plug. Element is cleanable, edgewound Case p/n VT3139 (A30411).
After you get everything cleaned up, you may need to adjust the control(by-pass)valve and the release valve actuator clearances. Pull that leak-off/vent tube off there and blow it out also.
Joe
Gregg wills
03-31-2005 16:22:08
 OK another question in reply to Joe (Wa), 03-31-2005 14:38:35
what is the recommended hyd oil for this application...you answered my first question on the money,,,at least i can repair it knowing what im getting in to..thanks gregg
Joe (Wa)
03-31-2005 17:11:38
 Re: OK another question in reply to Gregg wills, 03-31-2005 16:22:08
Case manual recommends engine oil. 5 wt below 32�F, 10 wt 32-60�, 20 wt above 60�F.
Some folks here use 10-30. I use a general purpose hydraulic oil mainly for the anti-foaming additive.
Doesn't really matter, oils are much better than when this tractor was built.
Joe
