SC Case Steering Loose
Glenn F.
03-30-2005 18:19:34
I have checked out the play in the steering of my '54 SC. Everything in the "gear box" looks good. I have turned the shaft 180 degrees and improved things quite a little. I think the remaining play is wear in the worm gear. I'm sure new gears aren't available. I may have to live with it but that 1/4 to 1/3 turn of play is quite noticable. What are my options? Thanks, Glenn F.
Camboted
04-01-2005 02:57:38
 Re: SC Case Steering Loose in reply to Glenn F., 03-30-2005 18:19:34
Glenn, here is one more thing we had to do to tighten up some Dc's. Turn your wheel and watch the steering wheel shaft. Does it rise and fall as you turn the wheel? If so you need to add a bushing under the top bearing. I really don't think your worm is worn that bad. The adjusting screw will compensate for a lot of wear on the worm.
L.Lamp
03-30-2005 20:47:47
There are many places to get the play out of the steering of these tractors. You have turned the first steering shaft 180 degrees(1), Adjust the end play out of this shaft at the opposite end(2), Adjust up the drag link at each end or replace with a better one(3) and (4), tighten the front steering arm so there is no play on the spindle. The key way may be worn here and a different spindle shaft will need to be acquired or the old one welded up and the key way recut.(5) The first arm to the drag link needs to be tight on the shaft, maybe an extra washer behind the nut.(6) With all these places of play eliminated, your tractor should drive very well. Good Luck! It won't hurt to take up any play in the wheel bearings either.
Glenn F.
03-30-2005 21:23:10
 Re: SC Case Steering Loose in reply to L.Lamp, 03-30-2005 20:47:47
Thanks for your response. I have done these things and still have some remaining play. I don't know how much they had new or exactly how much I have now, but I would think it would have been tighter when new. I have an adj. wide front on it. The drag link and tie rod ends were loose. Replaced them. Remaining play is in the box. Both arms are tight on their respective shafts. As I watch closely everything external appears 100% tight. I suppose worm gears do indeed wear out...? Are these standard worm gears one could order through a machine shop, (assuming this is indeed my problem)? Thanks, Glenn F.
Camboted
03-30-2005 23:04:08
 Re: SC Case Steering Loose in reply to Glenn F., 03-30-2005 21:23:10
I had a similar problem with a DC and the problem turned out to be the internal splines where the shaft that runs to the steering arm inserts in the stearing gear. I thought it was the worm gear also, but it was a sloppy spline. I had mine welded and re-machined and walla! No play
