C.AMICK
GARY CASE
03-30-2005 14:34:17
BUYING 530 DIESIL. HAS MILKY LOOK TO REAR END OIL IS THIS A BIG PROBLEM OR A FLUID CHANGE? has big front end loader. bucket goes up and down fine ,but the tilt is really slow to nothing. ckecked fluid (not running) looked good. has duell controls on tractor and the ones on loader. is there another place to check? thanx alot for any help. hope i didn't make a mistake comes with brush hog and rear blade (fair cond) paid 3000.00
C. Amick
03-31-2005 04:17:57
 Re: C.AMICK in reply to GARY CASE, 03-30-2005 14:34:17
The milky fluid is usually an indication that it has some water in it. You probably just need to change it. I'm not that familiar with the 530, but I don't think you made a mistake. Seems there should be a filter or at least a screen on the hydraulic system somewhere that should be cleaned or replaced. I don't know what the problem is with the tilt on the bucket. Could there be a restriction in the hydraulic hose, a crimped hydraulic hose or someone put hoses on it that are too small?
gary case
03-31-2005 04:26:14
 Re: C.AMICK in reply to C. Amick, 03-31-2005 04:17:57
thanx C. AMICK. GOING TO GO THERE NOW AND PLAY SOME MORE ON THE HYDS AND CHECK IT OUT A LITTLE BETTER. THE MOTOR STARTS RIGHT UP AND PURRS LIKE A KITTEN. IT'S HARD TO BELIEVE THAT A GROWN MAN CAN GET THIS EXCITED ABOUT A TRACTOR.
C. Amick
03-31-2005 06:14:48
 Re: C.AMICK in reply to gary case, 03-31-2005 04:26:14
I can believe it. :)
