L pto shaft
Goldie
03-30-2005 05:32:20
I"m trying to remove the PTO shaft from my L case. I removed the top cover of the transmission but I could only slide it out about an inch. Its was getting dark out so I gave up for the night. Any info would be appreciated
Tom Railsback
03-30-2005 19:52:10
 Re: L pto shaft in reply to Goldie, 03-30-2005 05:32:20
You should be able to get at the nut that holds the pto shaft through the clutch inspection handhole. There is a flat or dome shaped cover over the end of the shaft that's held on by 3 capscrews. Remove those and the cover and you can get at the nut on the shaft. It has a cotter key to keep it from turning on the shaft. (You should not have tio split the tractor.)
thehickdaddy
03-30-2005 08:16:14
that is because you have to split the tractor at the engine/trans to remove the pto. that is where the gear is that drives the pto, it is in the clutch compartment. you need to remove the nut on the end of the pto shaft in the clutch compartment. this will allow the pto shaft to slid out of it's drive gear and then out of the trans. sorry it takes a little work. everything else about the cases i love, but you usually do not remove pto assymblies very often so it is ok. have fun enjoying cases, we are down to 2 L's now, it is sad. thehickdaddy
AllanC
03-30-2005 12:46:18
 Re: L pto shaft in reply to thehickdaddy, 03-30-2005 08:16:14
The good news is that they are the easiest tractor in the world to split.
thehickdaddy
03-30-2005 19:30:30
 Re: L pto shaft in reply to AllanC, 03-30-2005 12:46:18
that and that they are they are just about the best tractors anyway. thehickdaddy
