mounting position of DC Case water pump
Okla Kansan
03-29-2005 15:18:35
Currently I have it with the grease zerk facing the right, standing in front looking at it. and it leaks bad. Is there a certain way it must be mounted? It could just be the sel between the pump and the block, but I wanted to make sure before I tore into it that either it did, or didnt go a particular way. Thanks.
Camboted
03-29-2005 15:27:20
 Re: mounting position of DC Case water pump in reply to Okla Kansan, 03-29-2005 15:18:35
Grease zerk is usually located on the top and a elbow type zerk is used, but I don't think this is causing your leak. I suggest you pull it apart for a rebuild, or get a new one from John Saeli. It will save you a lot of trouble and costs about the same as a re-build kit
