case 1000 hydraulics
stacey in ohio
03-29-2005 07:00:38
it's new to us first time out using it worked fine then all of a sudden the hydraulics stopped what is the first thing I should look for, the bucket still moves but the machine won't.
george md
03-29-2005 09:23:08
 Re: case 1000 hydraulics in reply to stacey in ohio, 03-29-2005 07:00:38
Stacey,
Give me an idea which model 1000 you have , that
will give me an idea where and which filters you
have. I have several 1000's and have had 2 of them
for more than 30 years,actually the loader for 37 years. If it's not low oil in the transmission, then look for a suction line pulled loose and sucking air. Send me an email with a phone # and I'll
call you. [email protected]
george
CASEPOWER
03-29-2005 07:39:30
Listen for the sound of a whineing pump from lack of fluid! Make sure you have the high/low lever behind your legs in gear. The terramatic drive was a very tough system. Does your unit have the hydraulic pressure guages for the tranny and charge pump pressure? Getting charge pressure to the converter is what makes it move.
