Model S crankshaft problem
tom
09-18-1999 19:08:16
has anybody run into the crankshaft being worn don't if the bottom pulley has been running loose for many years. sleeving the pulley is no big problem. any remedies for the end of the crank?
Chris Vangel
09-18-1999 22:15:40
 Re: model S crankshaft problem in reply to tom, 09-18-1999 19:08:16
If the crank is out of the tractor a machine shop could probably turn the nose of the crank true again. Then sleeve the pulley for the new dimension as you discussed earlier. This would most likely be the cheapest route to take. The other solution that comes to mind is to weld the crank and machine it down to its original size. This would certainly cost more. Anybody else got any ideas for a permanent fix?
