VAO Steering box Question
Trigg
03-28-2005 17:26:05
I took off the steering in box on my VAO (that I broke!!) There was a broken portion of the bolt that threads in the right side. It appears that the bolt pushed against the steering arm shaft to hold it in place. Am I correct or is the bolt supposed to attach to the shaft?
Steve (Md)
03-29-2005 03:31:17
 Re: VAO Steering box Question in reply to Trigg, 03-28-2005 17:26:05
I believe the bolt you are talking about is actually the shaft end play adjustment bolt with jam nut.
Trigg
03-29-2005 20:56:40
 Re: VAO Steering box Question in reply to Steve (Md), 03-29-2005 03:31:17
Am I assuming correctly that the shaft end play bolt is NOT permenently connected to the shaft?
mj
03-29-2005 21:44:37
 Re: VAO Steering box Question in reply to Trigg, 03-29-2005 20:56:40
third party image
Yes, you are correct.
mj
03-29-2005 21:24:34
third party image
