700 Case engine
Jake W
03-28-2005 08:14:04
How much is a 700 Case motor out of a combine worth. It is low hour but is stuck. Been shedded all the time until last spring and was already stuck then. A neighbor guy owns it.
Jake
Lamont
03-28-2005 19:44:49
 Re: 700 Case engine in reply to Jake W, 03-28-2005 08:14:04
My dad has one complete except for the distributor, NOT STUCK. It was seeping a little water into the pan. Probably sleeve o-rings. I swapped him out of the tractor minus the engine because I already had an engine I had started rebuilding. It is an LP engine. He'll take $500.00. It has got to be worth that much in internal parts. Compare that to what you're looking at. Maybe this will give you an idea.
Lamont
