headlights
Jim McVay
03-26-2005 16:55:48
Is there a sealed beam bulb that will work on the side headlights on a 351? Case # 5945115.
This is all I need to get ready for next weekends
tractor show in LaBelle Florida. Please help.
Joe Blahitka
03-28-2005 07:07:54
 Re: headlights in reply to Jim McVay, 03-26-2005 16:55:48
Hi Jim: If you would like some information on how I did this on my tractor, give me a call at 1-403-240-4771 or email me and I'll call you. My email is open. Joe
C. Amick
03-28-2005 05:11:01
Buy the smaller sealed beam units and split a piece of rubber vacuum tubing long ways down one side and open it up and silicone it to the outside edge of the lense. I used a large band clamp to hold it in place until it dried. You won't be able to see the rubber once you put the metal ring back on it.
Lincoln
03-27-2005 19:24:09
You wont find the sealed beam headlights. Joe Blahitka came up with some rubber rings that fit around a modern sealed beam. The rubber rings then allow it to fit your light housing. I'll send him an e mail and have him contact you.
case300
03-26-2005 18:06:39
That is a search that I don't think you'll be able to find. At least quite a few others have tried and not found them, my self included. There are after market lights that fit alright on the stand off with a bulb and reflector, but not a sealed beam that I know of. I have two sets of the lights that my sealed beams still work, but for my own tractors, and the after market lights have to remove the short bolt and use another longer one to go thru the stand offs. I done that for the first 300 I restored and they look exactly the same, but your time is short isn't it??
