SC manifold
Scott KY
03-26-2005 14:52:57
I recently bought a late model SC. It is a very nice tractor but appears to have been run with a bad manifold gasket. The # 4 Exhaust port is burned where it will not mate flush with the head. Does anyone have a solution other than another manifold? Does anyone offer new ones?
C. Amick
03-31-2005 04:28:32
 Re: SC manifold in reply to Scott KY, 03-26-2005 14:52:57
Assuming that the machine shop can mill it down, I would think about just building it up with a torch and a brass welding rod.
george md
03-26-2005 21:03:46
Scott,
If that one is burned too far to resurface, I repair them with cast iron weld , not arc weld. Here is a link to some manifold repair and some other thing also. There are 2 SC manifolds in the pictures, one had your problem exactly and the other is a dual fuel with the damper destroyed , that one is almost done .
george
Scott KY
03-27-2005 05:09:16
 Re: SC manifold in reply to george md, 03-26-2005 21:03:46
I have never welded cast iron. Can you give me some pointers?
george md
03-27-2005 13:15:34
 Re: SC manifold in reply to Scott KY, 03-27-2005 05:09:16
Scott, You will need an o/a torch , some cast iron rod (cast iron in stick form ), some cast iron welding flux . Then you need some practice on scrap before you start on the manifold.
There is an email addy in the link that I posted, be glad to answer questions there.
george
CK RICHARD
03-26-2005 17:45:35
SCOTT you can maybe have the manifold milled down if it is not to bad . there are reproductions OR I have a good used one and I live in KY.
Scott KY
03-26-2005 19:05:14
 Re: SC manifold in reply to CK RICHARD, 03-26-2005 17:45:35
I am going to see about milling this one down. What is the part # on the one you have? Where are you located in KY?
