Case 970 doesn't start
Corky
03-26-2005 11:23:56
We have a Case 970 diesel that just died the other night and we haven't been able to get it started since. It just turns over, but doesn't fire. The temperature here is about 30 degrees, but I don't think the fuel has gelled. I don't know much about diesels, other than they need fuel and air. What things should I check?
Thanks - Corky
Corky
03-26-2005 18:34:15
 Re: Case 970 doesn't start in reply to Corky, 03-26-2005 11:23:56
Got it started. Had to pull the primer pump out and pumped it. Started after we put it back together. Thanks to all responders.
big orange
03-26-2005 12:15:53
Is there smoke coming out the exhaust while cranking?If not,you're not getting fuel.
Corky
03-26-2005 14:03:36
 Re: Case 970 doesn't start in reply to big orange, 03-26-2005 12:15:53
No, no smoke. Do you think the fuel line could be frozen?
big orange
03-26-2005 14:25:29
 Re: Case 970 doesn't start in reply to Corky, 03-26-2005 14:03:36
This is the obvious,it didn't run out of fuel did it?
Corky
03-26-2005 14:28:43
 Re: Case 970 doesn't start in reply to big orange, 03-26-2005 14:25:29
No, there is fuel in the tank.
big orange
03-26-2005 16:05:01
 Re: Case 970 doesn't start in reply to Corky, 03-26-2005 14:28:43
If yours has a glass bowl on the side of the main fuel pump,check to see if the fuel looks clear,theres also a screen in the bowl,if it would have jelled sometimes its the screen,theremay or may not be a fine filter screen where the fuel line comes out of the tank,it could be plugged.Easy way to see if the fuel is flowing from the tank would be to remove the glass bowl from the side of the pump,fuel will run out quickly usually,if you have fuel there,probably would change and bleed the filters,if theres no pump problems it should start.Sorry for the long post.
Pat Tercho
03-26-2005 14:11:20
You need to do this systematically. Check for fuel flow out of tank to transfer pump, from there through fuel filters, then to injection pump. Most likely fuel filters plugged, but check things the whole way through. Use the owners manual to guide you. If she gets fuel and air and nothing is truly broken, it will start.
