CASE VA - EAGLE HITCH
JONESE
03-25-2005 12:22:17
HAVE A CASE VA. CAN AN EAGLE HITCH AND HYDRALICS FROM ANOTHER V SERIES MODEL BE ADDED TO THE VA? HOW DIFFICULT FOR A NOVICE?
tHANKS FOR THE REPLYS
Wheat Straw
03-26-2005 14:30:26
 Re: CASE VA - EAGLE HITCH in reply to JONESE, 03-25-2005 12:22:17
Jonese,
Case called the field installed hitch for the va series tractors an eagle hitch even though it had ball ends instead of the eagle claw on the bottom draft links. Wheat Straw
WALTER T. RENZ
03-25-2005 22:31:15
YOU WILL NEED A REAR DEFERENTAL HOUSING AND THE FINAL"S FROM THE TRACTOR YOU ARE WANTING THE PART"S FROM. THE PART"S ARE NEEDED TO MAKE THE CHANGE YOU CAN BUY ONE IN OHIO FOR 300.0 DEFERENAL AND HOUSING AND EAGLE HITCH ALL PART"S NEEDED IN CLUDEING THE PUMP AND LINE"S TO.
MikefromIowa
03-25-2005 20:39:29
Here is a VAC with the early add on eagle hitch. its on ebay for sale.
I think it would require switching the rear ends on early VAC which didn"t have that option availiable.
Joe (Wa)
03-25-2005 21:57:51
 Re: CASE VA - EAGLE HITCH in reply to MikefromIowa, 03-25-2005 20:39:29
third party image
That one on ebay is a pre 1949 high pressure lift, I done forgot what Case called it.
The 1949 and later eagle hitch was low pressure with the hyd piston and rock shaft just aft and below the seat as in the pix.
Joe
Jerry W
03-25-2005 17:58:34
Depends what year VA you have because a lot of the 1949 1950 tractors that did not come with the Eagle hitch do not have the rear end housing with the provision for mounting it. Sometimes you will have to drill and tap the torque tube for the oil feed and return. All VA's older than 1949 for sure had none of the provisions.
Most later tractors have the correct rear end and it is real straight forward. Case also offered a kit that included a bracket to mount a Eagle Hitch on a non Eagle hitch tractor but I have seen it only in a parts book.
Jerry
