Splitting a 1951 VAC
WOD
03-24-2005 13:25:21
HEllo,
I have to split my 51 VAC. I'm sure that torque
tube oil is going into the tranny. I want to replace the seals. Does anyone have the manual procedures/diagrams on the splitting procedure.
I have a IH shop manual but it is not very descriptive.
Thanks,
WOD
WOD
03-25-2005 07:32:55
 Re: Splitting a 1951 VAC in reply to WOD, 03-24-2005 13:25:21
Thanks Guys for the replies. This is great info.
The online manual is great too.
WOD
Augie
03-25-2005 07:09:00
Did that job recently. You'll find that the double-lipped seal at the front of the transmission mainshaft is made of unobtanium.
Stack a pair of CR11800 or CR12456 seals in the bearing cap. Put them in back-to-back so that the seal in front will keep the torque tube oil in the torque tube and the seal in back will keep the tranny oil in the tranny.
The countershaft is sealed with a gasket under the bearing cap. IIRC, that was NLA from Case. I cut one from thin gasket paper and sealed both sides with black RTV.
WOD
03-25-2005 07:31:43
 Re: Splitting a 1951 VAC in reply to Augie, 03-25-2005 07:09:00
Why the two seal numbers? Are they both the same? Thanks for the reply.
Augie
03-25-2005 09:17:19
 Re: Splitting a 1951 VAC in reply to WOD, 03-25-2005 07:31:43
They're so close in dimension that you can't tell them apart just by looking. I took the bearing cap to the local NAPA store and they came up with those numbers from measuring the old seal.
They only had one of each in stock so I took one of each. Worked out just fine.
Casekernel
03-24-2005 14:07:40
Your'e in luck. I posted about a clutch problem on my 49 VAC and got some good responses. My post can be seen, along with the responses, if you do a search of the archives. Type in "49 VAC Clutch" in the Case Forum. A topic "Well it happened" should come up. Keith from Oregon gave me a link to a VAC manual that was very helpful. Hope you can find it. Good Luck!
Keith-OR
03-24-2005 20:36:50
 Re: Splitting a 1951 VAC in reply to Casekernel, 03-24-2005 14:07:40
Here is the website with the manual. Lots of good info hre, just look through it and you will find what you need...HTH...Keith
