SC Hand clutch Carb 47
Running Man
03-23-2005 19:44:25
I am wondering if anyone has used one of the new Carb replacements to replace a 9667 carb instead of the rebuilt one. There are supposedly dimensions to follow but other sites are not as descriptive. I thought that the carb dimensions were the same on the 9667 as the later model SC tractors with the 11535. Will it fit?
L.Lamp
03-23-2005 21:30:11
 Re: SC Hand clutch Carb 47 in reply to Running Man, 03-23-2005 19:44:25
I have a '54 with the late model carburetor and I had to change the manifold because the exhaust ports were burned out. My carb fit with no problems. If you have to machine the intake and exhaust ports on the manifold you could get the bigger carb to close to the block. Make sure you machine it parallel to the old surface.
