Is it a 58 or 59
Jaker
03-23-2005 16:50:18
I went and looked at an 800 today. The serial number tag on the dash is gone.(Does anyone remake serial tags for the cases?) The block is stamped with a 814XXXX. This tells me that the tractor is a 1959. The nosecone has the tin radiator cap. Is this a mixed and matched model or did the early 59s have the cap too? Amazingly the tin cap is still there and it is in good shape. The dash is also near perfect. The tractor hasn't run in 4 years but it looks promising. Thanks Jake
caseman-d
03-23-2005 19:03:09
 Re: Is it a 58 or 59 in reply to Jaker, 03-23-2005 16:50:18
If the radiator cap itself is above the hood then it' should be a 59. If it has foot throttle on left and right side may also indicate a 59. Since the serial number off the bolck indicates the engine is a 1959 model. I do beleive the 59's also had the inline pump. I thought all 59's had the radiator cap above the hood, but don't know that to be a fact.
caseman-d
Jaker
03-23-2005 19:17:04
 Re: Is it a 58 or 59 in reply to caseman-d, 03-23-2005 19:03:09
Sorry, I forgot it is a gas. I also thought all of the 59s had the rad cap above the hood. That is what made me think this was a mixed together tractor. I do know that the a previous owner was at one time a mechanic at Case. So who knows what might have went on. I did not even look at the foot throttle. I was just curiuos because of the missing tag and the newer block number with the old nose cone. Thanks Jake
