Case S tractor with Wehr Road Grader
Lauretta Good
03-23-2005 15:06:17
We are in posession of a Case S tractor that was mounted with a Wehr Road Grader. We are restoring it and would like all of the information that we could find on it. So far we have not been able to find anything and nobody here knows about it either. Your help would be greatfull for any informationl
Thank you
dbb62
03-30-2005 17:00:34
 Re: Case S tractor with Wehr Road Grader in reply to Lauretta Good, 03-23-2005 15:06:17
Give these guys as much information as you can and they will tell you more than you want to know. 1. Serial # (should be a tag on the dash) but also stamped on engine flange on left side of tractor where it bolts to transmission.
2. Pictures - these are important. Post them under help identify, or here in forum. You can "search" the forum for directions on how to post here, as this has been covered many times.
Lauretta Good
03-23-2005 15:19:38
Need to add that the Case S is a 45 or 46 and the Grader is a One Man Power Grader
