VAC engine block
Jerry W
03-23-2005 14:48:42
Can anybody tell me what the difference is between the early and the late VAC blocks? I can see a couple of minor casting differences but I would like to know of the "real" differences if any.
I have 2 49's and they are about 300 apart and one has the early block and the other has the late block.
Jerry
Joe (Wa)
03-23-2005 15:17:21
 Re: VAC engine block in reply to Jerry W, 03-23-2005 14:48:42
Do the engine serial nrs start with the same letter? First letter "V" is earlier than "A".
Engine cam gear was changed tractor serial nr 5365687 according to the parts manual. Other changes include the water pump, hyd pump drive gear, governor & throttle controls, timing gear cover, manifold from 1 piece to 2 piece, etc.
I think that was what lead to redesignation of the engine serial nr from V to A.
Joe
Jerry W
03-23-2005 17:48:08
 Re: VAC engine block in reply to Joe (Wa), 03-23-2005 15:17:21
I never looked for engine numbers. I was talking about serial numbers. The early block has a VT149 casting number and the late one is something like VT359 or maybe VT859 - or maybe it is the other way around - my memory is not what it used to be.
Jerry
Joe (Wa)
03-23-2005 18:10:10
 Re: VAC engine block in reply to Jerry W, 03-23-2005 17:48:08
The engine serial nr is stamped into the block above the starter. It may be all the way up near the cylinder head gasket, vertical or hornizontal.
1949 was a year of several engine changes, you may need the engine serial nr to ID the correct part in your parts manual.
You have, I am sure, seen complaints posted such as why the VAC manifold won on ebay does not fit. That is because the 1 piece only fits before engine serial nr A47##### (mid 1949?) and the 2 piece manifold is used A47##### and after.
Joe
