genrator test on sc
n case
03-23-2005 11:19:09
best or a simple way to see if geneator is working or charging. background put a new amp meter on a sc. shows about 10 amp discharge when when lights are on [without tractor running], but with lights off and tractor running no + charge . thank
C. Amick
03-25-2005 12:53:27
 Re: genrator test on sc in reply to n case, 03-23-2005 11:19:09
First, make sure you are getting power from the battery to the generator. The fields must be energized in order for the generator to charge. One of the most common problems is the armature gets dirty and the brushes don't make good contact. Might try cleaning the armature a little with very fine sandpaper. Does it still have the old cut-out relay or does it have a voltage regulator. You could have some dirty or stuck contacts.
joher radiatorwala
12-01-2006 20:39:53
 letest price list in reply to C. Amick, 03-25-2005 12:53:27
FSEM AUTO RADIATORS
old chhani road,
opp.asopalav coc.,
B/H Amin ford,
Vadodara-390002
India
Ph:91-265-2773508
Dear sir
we are requested for your letest price list for radiators,or send it cataloge.
Regards
Joher Radiatorwala
