Case 580CK, Are they Hydrostatic?
Al_V
03-22-2005 16:07:23
Mid 70"s Case model 580CK (diesel), were these hydrostatic, clutch, or some tractors with each? Are these basically a solid Tractor? Any particular inherent problem areas to look at?
Thanks!
jdemaris
03-22-2005 20:33:01
 Re: Case 580CK, Are they Hydrostatic? in reply to Al_V, 03-22-2005 16:07:23
580CKs came with various options - none of them hydrostatic. They were available with standard clutch drive or torque-converter drive for the first stage of power tranmission and then there was a mechanical shuttle shift or an optional hydraulic clutch shuttle shift for the second stage of power transmission, and from there either a four speed transmission, or an eight speed. Some of the differentials have a pedal-operated lock, and some don't. Front axles came standard with 6 lug wheels or extra heavy-duty with 8 lug wheels, larger wheel bearings, and a 1 1/8" tie rod instead of 1" diameter. I think they are a very well built machine (and I was a Deere mechanic for much of my life). Main trouble area I've noticed with many 580CKs if they have the 188 diesel is a poorly repaired block. Seems 188s often throw a rod through the block in one favorite area. I've come across many that have epoxy, or bad welds in that area.
Al_V
03-23-2005 19:44:19
 Where is that trouble spot on the D188 block in reply to jdemaris, 03-22-2005 20:33:01
Thanks allot for the reply, Can you tell me exactly where that favorite spot is?
How do you tell if it's a D188, and what other engines did they come with?
Thanks again!
jdemaris
03-23-2005 20:54:20
 Re: Where is that trouble spot on the D188 block in reply to Al_V, 03-23-2005 19:44:19
It it's a diesel, I think they only came with 188s. The engine will have a tag on it, down low by the oil pan on the stater side of the engine. Mine has a 207 in it, but I'm the one that installed it. It's possible some of the newer 580s have 207s, but it's basically the same engine as the 188, just a little bigger pistons, a little more horsepower, and stronger rod bearing journals. So, maybe the 207s don't throw rods as easily as the 188s. The 188s are very good engines, but I guess when they DO get worn, they like to throw number three rod, and it tends to come out on the injection-pump side of the block. Just look for a patch of epoxy, or braze. Seems the spot they tend to poke through has no water jacket or oil galleys, so it CAN be patched sucessfully. When I bought my 580CK, the rod was hanging out the side of the original 188 block. Besides the hole in the block, it hit the camshaft and broke it in half.
Boxtop
03-22-2005 19:36:28
Torque converter in front of a shuttle forward reverse box in front of a 4 speed.
