HELP!!! I broke my 1947 VAO's steering housing
Trigg
03-21-2005 19:05:57
I need help. I was working with my tractor and hit a stump that turned the wheels completely sideways. I found that the cast housing where the steering wheel shaft meets the main body of the tractor has split open around the bolts. Can anyone help me find a new one? I don"t even know where to start. Thanks in Advance
Jim McVay
03-22-2005 09:24:18
 Re: HELP!!! I broke my 1947 VAO's steering housing in reply to Trigg, 03-21-2005 19:05:57
If the one Alberta Mike doesn't work out let me know. I have a 46 VAO that still has the steering
on it. Jim McVay Phone # 863-673-0363.
Trigg
03-23-2005 09:15:37
 Re: HELP!!! I broke my 1947 VAO's steering housing in reply to Jim McVay, 03-22-2005 09:24:18
Jim,
I just talked to you on the phone. Your email is hidden. My zip code is 98584 for shipping calculations. Thanks.
Jerry W
03-22-2005 05:58:51
Trigg
The early bare cast housing itself should be fairly easy to locate. If you have the non adjustable wide front which an "orchard" should have, the gears may be a bit tougher as you need a set that is reverse action as compared to the more common VAC. A VA and VAI should use the same gears.
Just a thought. Jerry
mj
03-22-2005 18:12:47
 Re: HELP!!! I broke my 1947 VAO's steering housing in reply to Jerry W, 03-22-2005 05:58:51
FIY - Orchards have NON-adjustable wide fronts.
Alberta Mike (again)
03-21-2005 21:32:26
Forgot to remove the hide feature. Try this link or use the following email address:
[email protected]
Alberta Mike
03-21-2005 21:25:59
So, do are you referring to the cylindrical casting that the steering shaft goes downwards through? This unit bolts to the main chassis of the tractor? The throttle lever is mounted on this part as well? I have one here if that's what you are talking about. I have removed my email hide feature so just hit on my name link.
Trigg
03-22-2005 08:31:30
 Re: HELP!!! I broke my 1947 VAO's steering housing in reply to Alberta Mike, 03-21-2005 21:25:59
The cylindrical casting bolts to tho part which in turn bolts to the torque tube. The steering arm sicks out the left side. The battery box sits right above it. Does that make sense? Ihave pictures.
Alberta Mike
03-22-2005 09:06:44
 Re: HELP!!! I broke my 1947 VAO's steering housing in reply to Trigg, 03-22-2005 08:31:30
That makes sense, what is it that you need, the cylindrical stem casting (that the shaft goes through) or the part to which that stem bolts (and has the steering arm sticking out of it)? You can email me directly at:
[email protected]
