VAC Case modifications.
Antique Puller
03-21-2005 15:40:31
Hello,
I recently purchased a VAC case out of a mans front yard. He told me that it ran in 2003, he was using it in his garden when it started knocking. He parked it and didnt touch it untill i picked it up. I cleaned the carb adjusted the points and tryed to pull it off, but the engine is locked up. I am going to use this tractor to pull antique stock 3200 lbs after i rebuild the engine. If anyone has any suggestions on bigger pistons, shaving the head, bigger valves, jeted carbs. I would love to hear from you.
Thanks, Antique Puller Guy
Jim McVay
03-22-2005 09:30:38
 Re: VAC Case modifications. in reply to Antique Puller Guy, 03-21-2005 15:40:31
See what your clubs rules will allow. I'm rebuilding one with 148 parts in a VAC block.
You can get 3 7/16 sleeve kits for a VAC. Most Case engines up to the 201s can be made to fit but all are longer than a VAC engine. Call me for further info. 863-673-0363.
Pawn
03-21-2005 18:42:45
Before you go to far with that motor NATPA allows a 148 to be put in them and you can get much more power out of them.
Augie
03-22-2005 10:48:25
 Re: VAC Case modifications. in reply to Pawn, 03-21-2005 18:42:45
I'd like to see that in writing from a tech committee member. The way I read the rules a G148 wouldn't even be Div5 legal in a VAC.
Pawn
03-22-2005 16:00:36
 Re: VAC Case modifications. in reply to Augie, 03-22-2005 10:48:25
Watched pass one in January at a pull. They noticed it wasn,t original asked what it was and then passed it.
Augie
03-22-2005 16:13:41
 Re: VAC Case modifications. in reply to Pawn , 03-22-2005 16:00:36
I guess I need to dust off that G201 that's sitting in the barn and drag another VAC out of the parts patch...
