david brown water pump grease
mj71
03-21-2005 10:16:43
Just bought a new water pump for a DB 990. Do I need to grease it before installing or is it sealed? The intstructions don"t say anything about grease, just to keep the coolant level full to avoid damaging the seal. There is a small hole on the bottom of the pump but no grease fitting. The original manual says to apply a high-temp grease very sparingly every 500 hrs. If I do need to grease it, what type of grease?
Thank you.
jhbg
04-07-2005 20:15:28
 Re: david brown water pump grease in reply to mj71, 03-21-2005 10:16:43
I have 3 db990's and have changed the pump of 2 of them and do not remember any grease fittings. The small hole in the bottom is a weep hole for any coolant that gets by the seal to get out
