case 530 CK backhoe clutch/ trans help!!
mike shaw
03-20-2005 16:49:34
I have a 1969 case 530 ck diesel backhoe. It seems to have a slipping clutch. It seems to lose motion if I start to work it, like using the front loader. But the funny thing is that if I pop the clutch 2 or 3 times it seems to grab for a few min then it slows down again. It is a 3 shifter type F/R to the left of the wheel, 1-4 on the trans, and Hi/Lo to the right of the wheel. This machine sat for 4 or 5 years before I bought it, could this be a factor? does the hydraulic system effect this type of transmission because it also needs some work.
G.B.
03-21-2005 18:16:56
 Re: case 530 CK backhoe clutch/ trans help!! in reply to mike shaw, 03-20-2005 16:49:34
Not to confuse the issue but my 530CK with Case-O-Matic has the dipstick on the rear right side of torque tube(if sitting on machine)just ahead of the battery. It looks like a regular engine oil dipstick. Gwinnybarge mentions a hex head dipstick. On mine this is behind and to the left of the shifter plate and is for checking final drive oil. My understanding is that torque tube level should be checked with machine running. If you have COM you"ll have "direct drive" lever on right side of steering column. Filter is in front of radiator. Hope this helps, Gary
gwinnybarge
03-21-2005 06:42:32
Yup. Check the torque tube fluid level. Dipstick located just infront of and to the right of where the 4-speed stick enters the floor. Takes a 1-1/4 inch socket or adjustable. Make sure the fluid is to the mark on the dipstick. Change the filter, which as Dennis points out is just in front of the radiator and behind the grill screen. The housing is mounted vertically with 4 bolts holding the cap on. Filters are pretty cheap and available through Case and NAPA. Search this site for filter numbers etc.
Sounds like a lack of fluid to either to torque converter, clutches or both. This could be simply the Hytran fluid level in torque tube and/or a bad filter. Pressure levels on the control panel gauge should give you an indication of this.
Dennis/Ohio
03-20-2005 17:06:50
Is it a Case-O-Matic or dry clutch?
I don"t know much about the Case-O-Matic but they have a oil filter in the grill area, a dipstick on the torque tube & a pressure on the dash that reads "good range".
Best wishes,Dennis..... ..
mike shaw
03-23-2005 13:20:51
 Re: case 530 CK backhoe clutch/ trans help!! in reply to Dennis/Ohio, 03-20-2005 17:06:50
I believe it is a dry clutch in this unit. It has a foot lever on it. It does not have a shuttle shift, just 1-4, hi/lo and F/R. Sometimes ths machine can"t get out of it"s own way, but not too long ago I pulled my 5 ton dump out of the mud, it took awhile but at times I had the front wheels off the ground. How can this be? Any thoughts? Thank You, Mike
sandy bennett
10-18-2005 17:44:17
 Re: case 530 CK backhoe clutch/ trans help!! in reply to mike shaw , 03-23-2005 13:20:51
looking for a web site where i can view breakdown coppies of all parts for the case 530ck backhoe.
Dennis/Ohio
03-23-2005 15:00:51
I think you would smell the burning clutch if you had a dry clutch (clutch like a heavy truck) You should check for the items the other guys told about. I"m sure the C-O-M has a pedal on the left side too.
Best Dennis.....
